2005 GC Climate Control Problem
Old Jan 26, 2011 | 09:44 PM
RedWing68's Avatar
RedWing68
Default 2005 GC Climate Control Problem
I am re-posting some questions I have on a climate control issue with my van. I have scoured this forum with no concrete solution.
The problem I am currently experiencing is my climate control only outputs heat from defrost/floor position. I cannot adjust the temperature or position.
Most features of the control unit work, including fan speed, rear defrost, rear wiper, rear climate fan. However, position, temperature, A/C, and recirculation do not respond.
I have run the blend door calibration test as outlined on this forum. After holding down the rear wiper and recirculation buttons for 5 seconds, it does go into calibration mode. When finished, the recirculation button LED continues to flash.
I then went to a junkyard and bought a Heater-A/C control unit and ran the calibration test on it with the same result.
Can anyone help me out here?
Old Jan 26, 2011 | 09:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Have you had the a/c check for codes with a scanner?
Old Jan 27, 2011 | 08:40 AM
RedWing68's Avatar
RedWing68
No I have not. Is that something AutoZone would be able to do? What result would I be looking for?
