96 Caravan - I connected the jumpers backwards...Duh!
Old Jan 29, 2011 | 07:47 PM
mpsfun's Avatar
mpsfun
Default 96 Caravan - I connected the jumpers backwards...Duh!
Ok in a astounding moment of brilliance I connected the jumper cables backwards and now the van will crank and has fuel pressure but no spark. (the battery had been dead for nearly two years...) I had jumped and ran the van several times while in storage, so I know it has no preexisting issues. I assume there is a fusible link somewhere in the harness for just such a case. Anyone know where that would be? I have already checked the under hood fuse box and none were blown, so a diagram or a pointer would be appreciated
Old Jan 29, 2011 | 10:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
What size engine to you have? And when it cranks,does it sound like you have compression?
Old Jan 31, 2011 | 10:13 AM
mpsfun's Avatar
mpsfun
it is the 3.3 V6 in excellent condition. because I have no spark I assume either I killed the PCM or blew a fuse or fusible link somewhere. I have fuel pressure and the motor cranks well, and I have swapped out the coil still no spark. because I know the battery was connected reversed I assume I indeed killed the PCM, but prior to spending that much cash I want to cover all my bases.
Old Jan 31, 2011 | 08:25 PM
22DODGE22's Avatar
22DODGE22
If you want to cover your basis, then you need to diagnose all the parts in the system to pinpoint the exact problem that way you don't throw unneeded parts at the problem. You should start by getting a factory service manual. This will walk you thru step-by-step instructions on how to find why no start.
