oil light???????
Old Jan 31, 2011 | 11:23 PM
chloedog1's Avatar
chloedog1
Default oil light???????
i have a 04 caravan the oil light recently started staying on when i first turn on the car, but will go off if i restart. theres plenty of oil and the van runs petty well but dos feel a little rough . i was wondering what the oil light means. why would it be coming onand go off after off and on again?
Old Feb 1, 2011 | 06:39 AM
22DODGE22's Avatar
22DODGE22
I was under the understanding when the oil light comes on and stays on or flickers when driving, that means there is something wrong with the oil system. It could be a bad sender or it could be the engine is shot and there is low oil pressure which is going to be a catastrophic failure.
Old Feb 1, 2011 | 09:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Okay,you are saying when you start the engine and let it idle,The oil lite stays on? And you turn the engine off and restart and let it idle again the oil lite is off?
Old Feb 2, 2011 | 03:09 PM
chloedog1's Avatar
chloedog1
Originally Posted by master tech
Welcome to DF
yes. I has happened numerous times and so far if i just restart engine it goes off again. I don't want to be negligent and keep driving if i am doing damage but the van does run pretty well and the light does go off. Any ideas?
Old Jun 28, 2011 | 12:02 PM
Neil Lienhard's Avatar
Neil Lienhard
What is the reason the oil light stays on until I restart
Old Jun 28, 2011 | 02:03 PM
master tech
If you don't hear any knocking sounds, I would remove the oil pressure switch and put a manual gauge in its place. Start the engine and see if the oil pressure at idle is in specs. If it is replace the switch.
