accelerator vs shifter issues
Old Feb 4, 2011 | 07:09 AM
pitsingerk's Avatar
pitsingerk
Originally Posted by 22DODGE22
I wonder if you can check a cable for being stuck? take off one end, push and pull, if it moves easily it isn't stuck? I'd think?
Cable is free, it's the linkage at the transmission that is frozen. I've sprayed the whole area down with PB blaster and turned the linkage back and forth, it's moving but not free enough, I'll keep at it tonight to try to get it moving. Does anyone know anymore about this, if I pull off the linkage and clean it up, would that be enough to keep it working or is this something that is internal to the trans that is causing the problem.
Old Feb 4, 2011 | 07:00 PM
22DODGE22's Avatar
22DODGE22
Your problem is not internal in the transmission. It's mearly corrosion issue of the shafts. The kick down shaft runs thru the centre of the shifter shaft. Over time corrosion can occur. As with any corrosion issues, you need to lossen that bonding affect. Lubricants such as Liquid Wrench can help reduce this problem. However if it is bad enough, you'll need to have a transmission expert remove the transmission valve body, disassemble the 2 shafts, remove the corrosion and reassemble. I'm pretty sure that level of repair would be a bit much for you. So for minimal cost and alittle time, attempting to free it yourself might just resolve the issue.
Old Feb 8, 2011 | 06:22 AM
pitsingerk's Avatar
pitsingerk
cut an old unused socket up to fit over the bracket to make it easier turn it, sprayed the hell out of it with pb blaster and kept working it back and forth. Got it freed up. Now I just have to adjust everything and put it back together. Thanks for the advice.
