power port/cig lighter issue.
Old Feb 4, 2011 | 02:58 PM
GAU-8's Avatar
GAU-8
Default power port/cig lighter issue.
I have the hanes manual for my 96 caravan..checking the index, and others tables I can't find anything that looks like "power port" (as its labeled on the actual part) compared to the book.
Anyways it stopped working, and I use it to charge my bluetooth/cellphone, additional electronics on constant long rides. I have checked all the fuses under the steering wheel, and all are intact. I did notice the part simply pulls out. Is it a built in fuse of sorts, and I just replace it like lightbulb when they go out? All wires, are clean, and connected.
But even if I just swap it out, and a done deal....what is it labeled per mechanics manual...nothing sounds close to "aux port" "power port" or "cigarette lighter"
Thx.
Old Feb 4, 2011 | 03:43 PM
inuyashamac's Avatar
inuyashamac
there should be a fule in side the charger that plugs in to the cigarette lighter
Old Feb 4, 2011 | 04:08 PM
jumpdrive2's Avatar
jumpdrive2
Old Feb 4, 2011 | 10:12 PM
GAU-8's Avatar
GAU-8
Thx, will have a look!
Old Feb 6, 2011 | 01:15 PM
GAU-8's Avatar
GAU-8
Arrrrgh. Nothing.
Checked both the 45 amp, and 25 amp fuses, they are good. I do not have a 6 amp fuse though, and everything on the junction block is labeled a specic amp fuse, and all are correct, and not blown. Do not see anything with a 6 amp fuse or labeled for one with a higher fuse in place. :/
