01 Caravan P0605, P0700 code
Old Feb 4, 2011 | 06:12 PM
BLKCBR's Avatar
BLKCBR
Default 01 Caravan P0605, P0700 code
I have an 01 Caravan and the check engine light goes on for a couple of days and dissapear for months and is beign doing the same for the past year. I finally scanned today and it gave me the transmission codes P0605 and P0700. The transmission works and shift perfect. What it could be?? probably bad connectors?? Any help would be appreciate it.
Old Feb 8, 2011 | 11:37 PM
BLKCBR's Avatar
BLKCBR
any help with those codes??
Old Feb 9, 2011 | 12:08 AM
steak59's Avatar
steak59
Pretty straight forward code that tells u to replace the Transmission Module...
I've seen those type of codes on car with no effect on performance at all. I assume u are out of waranty, and will pass emission test when code disappear, i wouldn't recommend to throw $500 away for it.
Old Feb 9, 2011 | 06:28 AM
22DODGE22's Avatar
22DODGE22
The only way to really resolve this issue is to have someone diagnose the transmission computer. Unfortunately the codes retrieved are done in the engine computer which isn't accurate enough to make an assumption the module needs replacement. The code readers only read PCM or engine computer codes. The trans computer will send a code to the engine computer but it's really generic and not enough information to diagnose the problem correctly.
Old Jun 23, 2011 | 06:54 PM
wstormyx2's Avatar
wstormyx2
engine light came on. code says transmission module. what does that entail and how much?
Old Jun 24, 2011 | 12:24 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You need to have someone get the trouble code out of the Eatx/transmission controller and post. This way we can start to help.
