01 Grand Caravan Problem help!
Old Feb 9, 2011 | 11:24 AM
undersiege's Avatar
undersiege
Default 01 Grand Caravan Problem help!
I have the same problem basically with my 01 Grand caravan. Initially it had an intermittent problem where it would dump black smoke and run missing like it was only firing on 2 cylinders. Afterward its just continuous. We have changed the engine and same thing. We can only get it to start when we charge around the wires on the coil and it runs with a terrible miss backfires and cuts off. We checked the wires in the harness around the area of the exhaust near the coil and found the sticked together but only the insulation, none shorted. Please Help, any suggestion?
Old Feb 9, 2011 | 10:28 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
With engine as bad that it is,Did the check engine lite come on? and what is the code or codes. You could have a bad map sensor or the injectors are staying on.The wire harness that has been a problem, you need to open the harness up and inspect.
Old Feb 10, 2011 | 09:06 AM
undersiege's Avatar
undersiege
Thanks for your reply Master tech.No codes were showing but at on time we saw 1684 which i think refers to the battery.Other wise the EMC was cleared and showed no codes. We even tried changing the emc.I will try to recheck the harness.
Old Feb 11, 2011 | 10:37 AM
undersiege's Avatar
undersiege
Master Tech is there any other area of the harness i should check specifically?
Old Feb 11, 2011 | 11:15 AM
master tech
That has been the only harness that i have been seeing problems with. There is another under the battery you can ck.
Old Mar 18, 2011 | 09:42 PM
undersiege's Avatar
undersiege
Unhappy
Good day again master tech. I tried checking the harness again but saw nothing so I tried changing it but was only able to find a harness for a Regular Caravan 01 not a grand. All of the plugs matched up except one or 2 like the ABS and some transmission plugs. It still did not start, just rolling. Does the slight difference in the harness make a difference?
