How can i program my 2002 Dodge Grand Carvan Sport remote?
Old Feb 16, 2011 | 11:59 PM
2002dodgecaravansport's Avatar
Default How can i program my 2002 Dodge Grand Carvan Sport remote?
hey i just bought a remote very similar to this one, http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
I never had a remote but i believe my van has the keyless entry system. How can i program the remote myself?
Old Feb 17, 2011 | 12:23 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If you don't have another remote, then you will need to go to the dealer and they can tell you if the van keyless entry.
Old Feb 17, 2011 | 12:49 AM
Well i did find this method, but i don't understand it. I'm a clueless girl
Program Method D (For use with AB vehicles not equipped with VTSS only)
1.
Locate the dark green program enable wire connected to pin # X of the 16-way data link connector under the left side of the instrument panel.
2.
Connect the program enable wire terminal to a good ground.
3.
Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.
4.
Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.
5.
Repeat step 4 to program additional transmitter.
6.
Disconnect the program enable wire from ground to exit program mode.
7.
Turn the ignition to the OFF position and remove the key.
Old Feb 17, 2011 | 01:42 AM
steak59's Avatar
steak59
that method is for the full size B-Van, not mini-van.
If you want to program it urself, you need a working remote. Or else you'll have to go to the dealership. I would say they'll charge around $30.
Old Feb 17, 2011 | 01:48 AM
Ok, thank you
