ABS sensor question
Old Feb 22, 2011 | 07:20 PM
22DODGE22's Avatar
22DODGE22
Default ABS sensor question
Trying to fix an 05 Dodge Grand Carvan SXT 3.8l. FWD w/sto and go. It's got an ABS code for the LR wheel speed sensor. I Ohmed the sensor but I can't find any specification for what the value should be. All the info I can find is for Checking voltage etc. Are these gen4 vans different how the ABS sensor works vs. Gen3? My dad had a bad ABS sensor on his 1999 Town and Country and I measured Ohms to find it was bad.
Old Feb 23, 2011 | 12:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
I look in the service manual for 2005. It doesn't show ohm resistance, but there was something for DC voltage. I'll post it,because i don't know if you already have it.
TEST ACTION APPLICABILITY
9 Turn the ignition off.
Remove the ABM harness strain relief to access wires.
Reconnect the ABM harness connector.
Turn the ignition on.
Measure the voltage between affected Wheel Speed Sensor 12 Volt Supply circuit and
ground.
Is the voltage above 10 volts?
All
Yes ! Go To 10
No ! Replace the Anti-Lock Brake Module in accordance with the
Service Information.
10 Turn the ignition off.
affected Wheel Speed Sensor Signal circuit.
All
Yes ! Go To 11
11 Turn the ignition off.
Reconnect ALL affected Wheel Speed Sensor circuit connectors.
Disconnect the affected Wheel Speed Sensor connector.
Measure the voltage of the affected Wheel Speed Sensor 12 Volt Supply circuit in the
affected Wheel Speed Sensor connector while reconnecting the sensor connector.
Did the affected Wheel Speed Sensor 12 Volt Supply circuit drop voltage to 0 DC
volts?
All
Yes ! Replace the affected Wheel Speed Sensor in accordance with the
No ! Go To 12
12 Turn the ignition off.
Measure the DC voltage of the Wheel Speed Sensor Signal circuit in the affected
Slowly rotate the wheel.
Does the DC voltage toggle between 1.6 volts to .8 volts?
All
Yes ! Go To 13
No ! Replace the affected Wheel Speed Sensor in accordance with the
Old Feb 23, 2011 | 01:17 AM
steak59's Avatar
steak59
What master tech said for diagnose
If you want to know it's operation, read this article
http://www.asashop.org/autoinc/aug2001/mech.htm
Old Feb 23, 2011 | 06:15 AM
22DODGE22's Avatar
22DODGE22
yes, I have all that information. I guess I'm just use to the old style sensor where you measure resistance. I guess I'll just have to follow the directions I have.
