rear wiper tension
Old Feb 27, 2011 | 08:50 AM
Jost's Avatar
Jost
Default rear wiper tension
Hello, Hopefully someone here can help me. We own a 2007 Gr.Caravan. The rear wiper is not compltely cleaning the glass. I have replaced the blade and this has not helped. The arm does not appear to be bent. I am wondering if there is a way to adjust the tension. If not, how difficult is it to replace the arm itself. I am assuming the hatch panel from the inside gets removed and than the arm is easily replaced? Any help/advise is greatly appreciated.
Jim
Old Feb 27, 2011 | 09:02 AM
22DODGE22's Avatar
22DODGE22
The arm probably needs the pivot lubricated. You can remove the arm externally nothing special about this arm's attachement. Identical attachment system to a lot of other wiper arms over the past 60+years.
Old Feb 27, 2011 | 09:16 AM
Jost's Avatar
Jost
Thank you ! Now the dumb question, how do I remove the arm? I don't see a clip or set screww, is this just press fit? If yes, should I just wrap a rag around it to prevent scratching and than pull off with channel lock plier?
I do appreciate the advise.
Old Feb 27, 2011 | 09:28 AM
22DODGE22's Avatar
22DODGE22
If it was my vehicle, I'd pop off the plastic cover cap where the arm attaches to the shaft to access the retaining nut, then I'd use a socket of appropriate size to remove fastener located under cover. But I'm just guessing, IDK how your van is put together
Old Feb 27, 2011 | 12:10 PM
Jost's Avatar
Jost
Thank you Dodge22. The van is so dirty that I had not even seen the plastic cap. I will give this a shot.
Jim
Old Feb 27, 2011 | 12:41 PM
22DODGE22's Avatar
22DODGE22
I really have no clue, I'm just guessing.
Old Feb 27, 2011 | 07:14 PM
Jost's Avatar
Jost
You guessed right! It worked out fine.
Thank you, Jim
Old Feb 27, 2011 | 07:45 PM
22DODGE22's Avatar
22DODGE22
I was totally guessing. There's 2 common ways that wiper arms are held on. I figured I had a 50/50 chance of getting it right. I don't have one of these vans but I figured my dad's 1999 was the other method so I guessed the other.
Old Mar 5, 2011 | 11:10 AM
kklblue's Avatar
kklblue
I have the same issue - I am going to try this as well.
Thanks!
Old Mar 6, 2011 | 09:56 AM
Jost's Avatar
Jost
Good Luck. Let me know how it works out. Mine was so bad that the wiper was unuseable. Now , while not sweeping 100% is only missing a small spot, I would say 98% effective. I think that in time it will improve as it seemed to have been stuck.
