97 dodge caravan
Old Feb 27, 2011 | 05:33 PM
velkur's Avatar
velkur
Default 97 dodge caravan
I just bought a 97 caravan with a 3.0l. Just after i bought it it started a what sounded like a high pitch metal grind. I have replaced the idle pulley alternator and belt. first was the idler because i felt a rough spot int he bearing when turning it. then was the alternator. Sprayed wd-40 on the bearing and ran it and the noise went away. then i replaced th ebelt. everytime it got better. now it sounds like a belt noise and is only with a load on it (engine rev) but i just replaced the belt.
Any Ideas what the noise is? The only thing left is the tensioner and I see that the pulley is available separate and the power steering pump.
Old Feb 27, 2011 | 10:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The problem could be the fan belt tensioner or the fan belt is out of alignment between the ALT and the P/S pump. I have also seen new fan belts make noises too.
