2001 GRand Caravan airbag light on
Old Mar 20, 2011 | 07:39 PM
Pecke's Avatar
Pecke
Default 2001 GRand Caravan airbag light on
The airbag light is on on my grand caravan. I had other issues with the ABS warning light. That was fixed by reconnecting a corroded wire under the fuse box. The clockspring isn't suspect becuase the horn and cruise control work....any ideas?
Old Mar 20, 2011 | 08:02 PM
22DODGE22's Avatar
22DODGE22
Passenger side seat belt tensioner.
Driver side seat belt tensioner
Clock spring (yes it can be bad and stil have horn and cruise)
Squib connectors
Bag modules,
CAB
impact sensors
fuse
wiring
These are just a few of the possible problems. I found my neighbors 03 caravan to have an Airbag light. I used a code reader to find the Passenger side seat belt tensioner is open.
Old Mar 21, 2011 | 12:24 AM
master tech's Avatar
master tech
Site Moderator & Tech
You need to get the stored or active codes from the air bag module and post.
Old May 21, 2012 | 02:19 PM
k20duser's Avatar
k20duser
New Member
Hi, can anyone tell me exactly where the "passenger squib #1" is located on a 2002 caravan...
Thanks
Old May 21, 2012 | 11:05 PM
master tech
That would be the air bag thats in front of the passenger. You will find the yellow connector on the inside of the dash near the heater control. Just open the glove box door and you will see it.
Old May 4, 2013 | 10:18 PM
sgheewala's Avatar
sgheewala
hi to all
can anyone please tell me how can i find driver seat belt sensor in my 2006 Grand caravan 3.3,i have air bag light on
i have brought to my mechanic to scan the code & he said is driver seat belt sensor please advise
thanks
