A604 to a606 wiring
Old Mar 29, 2011 | 08:12 AM
kevgene's Avatar
kevgene
Default A604 to a606 wiring
Does anyone know how to adapt the seperate range sensor & neutral switch connectors plug wiring for the Dodge A604 transaxle to the single range sensor plug on the newer A604 transaxle ? A diagram or directions on what wire goes to what is what I'm looking for. Thanks
Old Mar 29, 2011 | 09:54 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IDK your answer but welcome to the site.
Old Mar 29, 2011 | 10:18 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. What model and year is your vehicle?
FF
Old Mar 29, 2011 | 11:04 AM
kevgene's Avatar
kevgene
Default Dodge Caravan
Sorry. I guess I should have mentioned that. I have a 1996 Caravan with a A604 with the two seperate sender connections for the transmission range sensor & neutral position switch on SIDE of case. I need to be able to adapt the wiring to the one single transmission range sensor connection on the TOP section of the case by the module on the newer A604 transaxle. Thanks
Old Mar 29, 2011 | 01:51 PM
1969CoronetR/T
vaffanculo
I will move this thread to the Caravan section,
FF
Old Mar 29, 2011 | 10:23 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Take a look at the other post you have. The answer is there.
