Clock Spring Replacement Procedure
Old Apr 25, 2011 | 12:36 PM
Tizzy1's Avatar
Tizzy1
the passenger airbag connector is to the right of the radio, you can see it through the glove box opening. It's the same as the pretensioner issue, the connector makes bad contact. If you wiggle it and it's the problem, the airbag lamp will go off. No, no reset, when the problem is fixed, the lamp will go out.
Old Apr 21, 2018 | 07:41 AM
schwede133's Avatar
schwede133
I want to replace the clockspring on my 08 Durango. Do I have to center the new clockspring? It`s a Standard CSP211.
Thanks.
