2003 Vibration
Old Dec 15, 2011 | 02:10 PM
mrtinker's Avatar
mrtinker
Default I'd like to make a recommendation...
I just wanted to 2nd the opinion on replacing all of the motor/transmission mounts. I've been through this ordeal in detail..... i would look for obvious causes first (as you have) but before doing anything else, I'd replace all of the mounts before going further... I think I paid about $160. for all of them in our 97 Grand Caravan... It could be even less if you have the ability to press out/in just the rubber inserts in each of them.
This is a lesson I've learned the hard way!
Hope this helped someone else out there!
Old Dec 16, 2011 | 01:49 AM
CBSamson73's Avatar
CBSamson73
Default Inner CV joint support
I'm having similar vibrations in my '06 DGC. After playing around with the CV axle, it seems that it isn't supported properly; it's kinda cantilevered a good distance and supported at the splines only. I notice it flops around +1/4 inch. I doubt there's a bearing support in there else it would be impossible to install the CV axle.
I just put in a new axle less than 1000 miles ago and still vibrating like crazy when accelerating.
Does this make sense? Is there is a way to repair/replace the female splines.
Old Dec 16, 2011 | 09:05 AM
fish2222's Avatar
fish2222
Actually, I ended up replacing the drivers side cv shaft AGAIN and it is smooth as can be now. I did buy one of the aftermarket outer bearing/seal combo setups, but I have not installed it yet. I am going to give it a few months and see if it comes back again. I am hoping I just got a bad cv shaft last time, but since it was supposed to be new and not remaned, I would think it should have lasted longer. I do think I need new sway bar bushings, as I do have a clunk when I hit bumps, and it has new struts and upper mounts too, so that is about all that is left to clunk around.
Old Dec 17, 2011 | 02:38 PM
scotter5's Avatar
scotter5
Did who ever you took back the cv shaft to give you a hard time about getting an exchange? How were you able to convince them to exchange it if there weren't any signs on the cv shaft as being bad?
Thank you. I will look forward to response.
Old Dec 18, 2011 | 09:56 PM
fish2222's Avatar
fish2222
Actually, I bought it from O'Reilly's, so it has a lifetime warranty. I usually don't have any issues returning anything to them as long as I am getting the same part. I told them that I had already checked tires, brake rotors, and motor mounts. The asked me basically how I knew too, and after I told them everything I checked, they gave me the new one. I am still waiting to see if the vibration comes back again when the shaft gets a little wear.
