Smoking
Old Apr 29, 2011 | 09:12 PM
HuffmanFamilyof4's Avatar
HuffmanFamilyof4
Default Smoking
it seems that ever since I changed the MAP sensor my 3.0 started smoking but only when it sits for a minute while running then no smoke while driving, but here is whats strange. it has a sulfur type smell to it. would that be the EGR valve any help would be greatly appreciated. thank-you
Old Apr 29, 2011 | 09:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
Could be just the valve seals that are leaking and then clears up after it been running.
Old Apr 30, 2011 | 12:37 AM
Cougar41's Avatar
Cougar41
Model year?
Only reference to a sulfur smell I've read is either the catalytic converter is eating itself or the battery is shorted and overheating. In your case I would suspect the cat converter considering you just changed a major component that effects the air/fuel ratio in the MAP sensor. That said, if it's so bad you're smelling sulfur fumes I would expect the SES light is on indicating codes are present. You can cycle the key to read them or head to an Autozone or the like and have them read with a scanner for free.
Old Apr 30, 2011 | 04:54 PM
HuffmanFamilyof4
2000 Dodge Grand Caravan with the 3.0 and I just changed the alternator and battery last year do to overcharging (Rotten egg smell) the light did come on and the only code that showed up was a low voltage reading from an O2 Sensor(after the cat)
