Ajusting the parking break
Old May 2, 2011 | 04:42 PM
doodie1's Avatar
doodie1
Default Ajusting the parking break
Can someone please tell me how this is done (the right side)thank you
Old May 2, 2011 | 09:52 PM
wtribeflyer's Avatar
wtribeflyer
You don't mention what year your van is but as far as I know....They parking brake is self adjusting and cannot be manually adjusted. It is done with a ratcheting adjuster at the parking brake pedal mechanism. If one side seems out of adjustment, you probably have some other problem. The self adjuster effects both cables equally
Old May 3, 2011 | 03:51 AM
doodie1's Avatar
doodie1
Thank You for getting back to me,I have a 1999 Dodge Caravan,yes the right side needs ajusting,the drivers side is fine.So I guess It's something else?
Old May 3, 2011 | 10:06 AM
wtribeflyer
Look underneath the car directly below the drivers seat. You have to be on your back and looking up. You will see the parking brake cable. It comes from the pedal assembly as a single cable. Then it splits into two and the cables go to their respective wheels. Follow the cable all the way back to the one you say needs adjustment. It goes through tubes and bends. Look for damage or ? Tug on it and see if its loose. It should be as snug as the good cable is. Have someone set the brake with you looking and see if both cables are moving ok. If all looks ok then the wheel and brake drum must come off. Not sure if you have disc or drum at the rear wheels. Good luck.
Old May 3, 2011 | 10:57 AM
Tizzy1's Avatar
Tizzy1
Disc or drum brakes in the rear?
Old May 3, 2011 | 12:19 PM
doodie1's Avatar
doodie1
Default Thank You
I have drums on the back,and the passenger side cable works,but doesn't seem to hold the wheel tight when i apply the emergency break,the wheel spins freely.
Old May 3, 2011 | 01:13 PM
Tizzy1's Avatar
Tizzy1
With drum brakes, if the shoes aren't adjusted correctly, it affects e-brake performance. Possible the shoes are too loose.
Old May 3, 2011 | 04:01 PM
doodie1's Avatar
doodie1
Thank You Tizzy1 that was the problem,ajusting the brake shoe fixed my problem,Thx Again
Old Dec 6, 2011 | 12:00 PM
dorough's Avatar
dorough
I have the same problem... ineffective parking brake. I press the pedal and it's essentially no use. I wonder if I need to check the rear shoes as well. Can you please define "adjusting" the brake shoe? What exactly needs to be done to it?
Thanks!
Old Dec 7, 2011 | 12:15 PM
doodie1's Avatar
doodie1
Thanks!
On your brake shoes in the back there is a little wheel(it has a star or teeth ),you have to adjust that wheel from the back of your wheel,you will see a little hole there that you can put a flat head screwdriver through to adjust.
Hope this helps
