Transmission slipping
Old May 6, 2011 | 12:21 PM
markracer72's Avatar
markracer72
Default Transmission slipping
98 Grand Caravan, 198000 miles. 3.8 engine. Transmission pulls good until shift to 2'nd gear then slips. Checked codes and got generic p0734 improper 4'th gear ratio. Changed filter and fluid. Fluid was burnt, but no excessive metal in pan. When it starts to slip you can stop and put it in park then back to drive and it slips. You can back up about 50 feet and put it back in drive and it will pull hard until it tries to shift again. Help!
Old May 6, 2011 | 11:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Were there any other codes? And do you know what the CVI's were? This would help to give you an ideal what maybe wrong with the transmission.
Old May 7, 2011 | 08:35 AM
markracer72
No other codes. You lost me with CVI's. What is that? Thanks.
Old May 8, 2011 | 11:12 PM
master tech
CVI's means Clutch Volume Index. The CVI specs tell me if the transmisson is within specs or if they are out of specs. From the information I am reading, I'm guessing you may have a broken hard part.
