2006 T&C A/C not working
Old May 12, 2011 | 07:17 PM
Steeled's Avatar
Steeled
Default 2006 T&C A/C not working
Only blowing warm air, guessing it might be the rear evaporator. Any suggestions? If the system is empty of freon, will it prevent the compressor from running to protect it from lack of lubricant? It does not seem like compressor is kicking on either.
Thanks in advance,
Ed
Old May 13, 2011 | 12:45 AM
Cougar41's Avatar
Cougar41
Yes, if the pressures aren't correct the pressure switch won't allow the compressor to run. If the compressor fuse is good have the system serviced. If the refrigerant has leaked out make sure they install a dye so the leak can be found.
Old May 13, 2011 | 10:08 AM
Tizzy1's Avatar
Tizzy1
How many miles on the van?
Old May 13, 2011 | 12:25 PM
Steeled's Avatar
Steeled
Only 46K miles on the van, so the rear evap is covered by the warranty extension that Chrysler issues. I have heard that these commonly fail in northern climates due to road salt corrosion.
Ed
Old May 13, 2011 | 02:25 PM
Tizzy1's Avatar
Tizzy1
Correct. Chances are in the 90% range that is your issue.
Old May 14, 2011 | 10:55 AM
Steeled's Avatar
Steeled
Thanks for the information gentlemen. Will get it into the dealer soon.
