Cruise not working after installing
Old May 14, 2011 | 04:48 PM
  #21
Tizzy1's Avatar
Tizzy1
like I said, lots of changes from '96 to '97. Here is a '96 switch diagram. the dimming module runs the led in the switch.
Old May 14, 2011 | 04:49 PM
  #22
Tizzy1's Avatar
Tizzy1
missed one
Old May 14, 2011 | 04:59 PM
  #23
ShelbyGT550's Avatar
ShelbyGT550
So from that diagram one wire goes to the Juntion Box so I assume it's a power wore? The other is a sensor wire going to the brakes and the other goes to the buttons? Correct? Can you get me the wire colors? I got pink with purple tracer not really sure where it goes I ran it to the brakes , light blue with red tracer going clock spring and a yellow with orange tracer also did not knownwhere it went as it went up in the dash of the other van. I hooked it also up to the brakes
Old May 14, 2011 | 05:11 PM
  #24
Tizzy1's Avatar
Tizzy1
The light blue with red tracer wire a the module comes from the cruise switches. The pink with the light blue wire comes from the control side of the park lamp relay. The yellow with red tracer comes from the 12v feed side of the brake lamp switch.
Old May 14, 2011 | 05:25 PM
  #25
ShelbyGT550
Ok where is the control side of the park lamp relay? And what does it do? I mean why do they have a wire running there?
Old May 14, 2011 | 05:35 PM
  #26
Tizzy1's Avatar
Tizzy1
do you get the diagrams? The park lamp relay is in the Junction block. It's the fuse block inside the car. It probably controls the intensity of the led on the switch. It's probably brighter with the lights off and dimmer with the lights on.
Old May 14, 2011 | 05:57 PM
  #27
ShelbyGT550
I just hooked up the one with the cruise light on the switch and it lights up when pressed.
Old May 14, 2011 | 06:01 PM
  #28
Tizzy1's Avatar
Tizzy1
then check for codes, turn the key on / off / on / off and on. It should display a number code in the odometer.
Old May 14, 2011 | 06:06 PM
  #29
ShelbyGT550
No number code in the od check engine spits a 12 and a 55,
Old May 14, 2011 | 06:14 PM
  #30
Tizzy1's Avatar
Tizzy1
well, now you need to hook up a scan tool and see if the PCM is seeing the switch inputs correctly, see if it can actuate both of the solinoids, etc. Not much more you can do without one.
