3.0 Timing belt install problem
Old May 14, 2011 | 10:24 AM
Dan S's Avatar
Dan S
Default 3.0 Timing belt install problem
Hope someone can help. I need a good timing belt diagram with instructions. I line up the crank to TDC, set the marks on the cams, install the belt then turn the engine two revolutions and recheck. No matter what I do I end up a tooth off on the rear cam. If I back it up a tooth, then its off a tooth the other way. I have heard of this problem before, just cant find the answer. Please help, thanks.
Old May 14, 2011 | 12:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Send your email address and I'll send you a picture on how it looks. Which way are you turning the crankshaft?
