Alternator Mod
Hi, does anyone know if I can do this with my 2005 Dodge Grand Caravan? I know this is not the right section but maybe some of you guys here can help me. I'm sure its possible and I've already ordered my diodes but it's nice to have some confirmation. Does anyone know specifically what wires I should splice up? I'm thinking it's most likely the wire that's not red or black.
http://www.scoobymods.com/raise-your...0547.html?amp;
These are the diodes I ordered. Are the the right ones? -
http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWNX:IT
I'm doing this mod because my vans electrical system on a cold start produces high 13V's sometimes 14.1V. After some time of driving it'll go to mid 13's. With my stereo, the voltage sometimes drops to 11.9V with the engine running!
You'll just work the alternator harder. yeah, they'll work, but the battery also has a temp sensor, if it gets too warm, then charging stops regardless of how many diodes you use.
The wire is the voltage feed back to the computer. Not sure which color.
