2008 Dodge Caravan Blower Motor Replacement HELP!
Old May 25, 2011 | 06:34 PM
michaeloberg's Avatar
michaeloberg
Default 2008 Dodge Caravan Blower Motor Replacement HELP!
So my 2008 Dodge Caravan has another mouse in the blower motor, causing it to vibrate and stink like holy heck. The first time the dealer replacement or cleaned it out the first time for free, this time I'm out of warranty. I am pretty mechanically inclined and am looking for instructions on how to replace/clean out the front blower motor for the ac/heater.
Old May 25, 2011 | 08:08 PM
michaeloberg
Default FIXED pics and instructions attached!
Step 1
Remove contents from glove compartment
Step 2
Remove Glove Compartment
Step 3
Look closely and you will see the dead mouse
Step 4
Remove plastic clips holding the carpet to the glove box (2)
Step 5
Remove Harness
Step 6
Remove 1st Screw, You will need a torx bit
Step71
Remove 2nd Screw
Step 8
Remove 3rd Screw
Step 9
Remove blower motor and clean contents
Step 10
Grab a towel with cleaner and put your hand through the housing and clean good while the motor is out!
Step 11
Replace in reverse order, attached is the pic of the stinky mouse.
Sad part is the dealer wants to charge for this 15 minute fix!!!
