2000 caravan leaf springs
Old May 29, 2011 | 08:39 PM
crowleyjonathan's Avatar
crowleyjonathan
Default 2000 caravan leaf springs
i have a 2000 caravan i was wondering if it would be possiable to put thicker leafs sping in it to get a little bit of a lift because where my camp is there is rough terrain and i almost bottomed out out and dont want to risk it and im on a pretty tight budget any ideas ?
Old May 29, 2011 | 10:18 PM
master tech's Avatar
master tech
Site Moderator & Tech
Have you throught about air shocks?
Old May 30, 2011 | 10:33 PM
me0418840987's Avatar
me0418840987
I use my Grand voyager as a work truck, and tried to add leaves under the existing ones, but ran into trouble with the way the springs are attached to the axle. They are sanwiched between a rubber bushing, and have a solid locating pin 1/2 inch diameter, 1 inch long attached permanently to the bottom of the spring, and goes thru the bushing into the spring perch on the axle. also, the cap that secures the spring, and bushing assembly is non adjustible, meaning nothing can be added to the thickness without having a new spring hold down made. Google Timbren SES helpers, or Hellewig add on helper springs. Also, Monroe makes overload shocks.
Old May 31, 2011 | 05:36 PM
crowleyjonathan
Would this give it any lift during regular driving conditions ?
Old May 31, 2011 | 09:57 PM
hemi4spd's Avatar
hemi4spd
most spring shops will add a leaf for a reasonable price. this is better than stiffer shocks and will increase the weight load the van will carry. adding a leaf will lift the rear slightly but not as much as those handicap conversion vans
