pcm reset drive cycle not ready
Old Jun 2, 2011 | 08:34 PM
pwk's Avatar
pwk
Default pcm reset drive cycle not ready
also posted under kubitzpat
if i pull a sensor lead and complete a drive cycle it should generate a DTC plug the sensor back in complete a drive cycle if no DTC generated does this definitivly mean bad PCM ?
Old Jun 2, 2011 | 10:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
It depends on the sensor, and yes it should give you a DTC. But it may not come right away.
Old Jun 3, 2011 | 04:59 PM
pwk's Avatar
pwk
Default saa
Thanks
I'll try TPS first then up stream o2 and keep you advised
