electrical issues
Hello i am having some problems with my wife's 2006 caravan 3.3l.Sometimes the van will not start when you cycle key, the pump is very loud. if you cycle the key 10 to 20 times the fuel pump gets quiet and starts fine with no problems. If i take the fuel pump relay out and put it back in the van starts right up. I put a new relay in and still doing the same thing. The wipers are working the same way, sometimes they work sometimes they don't, and if you take the relay out and put it back in they seem to work again.
Thanks
Thanks
Welcome to DF
You could have a bad connection under the PDC/IPM or a FCM( Front control module). You can remove the FCM and check the connection and add dielectric grease to the pins, and recheck. If still have a problem, I would recommend a shop to look at the problem.
Ok i have tried what you suggested and it fixed the problem for 2 days.Now the wipers are working fine but if the van sits for a few hours you have to cycle key to get the fuel pump to pick up the fuel.When you cycle key fuel pump is loud but if i take fuel pump relay out and put it back in the fuel pump gets quiet and starts.
Thanks
Thanks
