[4th Gen : 01-07]: please help me, dodge caravan 2002 get hot and stop running
Have you changed anything yet and have you checked for codes? Any additional details on the symptoms?
5-10 min. Of running it just shuts down, then the rely's clicks. can't figure out which one but I've changed most of them. During this I've noticed what sounds to be like the fuel pump runing, loud and nonstop. I've change pressure regulator, fuel filter,and spark plugs. Also had code to replace cam and/or cranck sensor and so I replace them both. Now all that code reader has is a C; O; OH; EV. Which I beleave are just little monitor problems. So bacicly runs 5-10 min. Or about when it would git to normal water temp. Then shuts off with rely and fuel pump acting up.
New to the forum but I has the same issue a while back with an old sport, 200-2001, and the issue turned out to be a crack in the lower part of the coolant reservoir. Hot glued the crack and never had the issue again. Funny thing was the temp light never came on nor any other engine lights, the car would get to temp and then stutter, buck and shut off. hope all works out.
