2006 T&C - Vibrating Steering Wheel
Old Jun 15, 2011 | 09:19 AM
xevier69's Avatar
xevier69
Default 2006 T&C - Vibrating Steering Wheel
Hi,
Sorry, but I have another question to ask. Any idea why I have vibration in steering wheel when applying the brakes? It is not bad when driving in the city but on a highway it is quite noticeable. I have tried to shift to Neutral when driving on a highway and the same thing happens. I don't feel any "loose" condition, no noise or bangs from suspension. The only thing that I have are very worn tires. Could that be it? Could lost balance and excessive wear cause the vibration? The brakes were serviced about 4 months ago. What about the rack and pinion? I have no leaks nor "morning stifness". No side pulling, etc.
Your suggestions are always appreciated.
Thanks
Old Jun 15, 2011 | 01:56 PM
Atrious's Avatar
Atrious
The rotors sound warped. Most common issue during braking vibration.
Old Jun 15, 2011 | 06:14 PM
Cougar41's Avatar
Cougar41
Only when applying brakes? Warped rotors. If there's enough thickness left a shop will turn them on a lathe and true them up for you.
http://auto.howstuffworks.com/auto-p...ake-rotors.htm
Old Jun 16, 2011 | 08:47 AM
xevier69's Avatar
xevier69
I'm not sure is there is enough thickness but I will consider new rotors. They are only about $40 a piece. Thanks for the advice.
Old Jun 16, 2011 | 11:10 PM
Cougar41's Avatar
Cougar41
The shop has to measure the thickness before they can legally turn them.
