bucking,and stalling,no speedometer
Old Jun 16, 2011 | 12:04 PM
bigmike619's Avatar
bigmike619
Unhappy bucking,and stalling,no speedometer
Hi;my 2001 dodge grand caravan/sport has a serious problem with speedometer not working,runs for a little while,but then starts running rough,and will stall after i put it in drive.it,s a 3.3 ,3speed automatic.I did disconnect battiery when workong on it to change out the vss output,mybe I need to change input one as well???.need help asp,only vechicle to get to work,can,t use it now.can anyone direct me,or help me to solve this problem without taking it to a shop.also my o2 sensor on the cat is diconnected,because my exhaust is broken at the flex joint.
Old Jun 16, 2011 | 10:33 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The o2 sensor could cause the engine to run rough. On the speedo, 3.3 engines didn't come with a 3speed transmission. I think you mean a 4 speed? I would check the wires at the output sensor connector. A wire maybe broken inside the connector.
Old Jun 25, 2011 | 11:35 PM
multimedia51's Avatar
multimedia51
I had a similar issue a month ago. the engine ran really rough. Died after a few seconds of driving. Would start right back up but did the same thing. It felt like the engine was almost jumping out of the hood. I took the plenum off to clean the carbon off, and thats when I noticed that the fuel injection harness had a wire showing. I took the tape off the harness and it was melted together. I had 8 codes at that point. Bought a used harness from the junkyard for $100.00. Replaced and all is well. The harness is located right over the exhaust. If you can take a look at it. This might be your problem. Hope this helps.
