Corroded strut Tower
Old Jun 19, 2011 | 10:47 PM
kathiep's Avatar
kathiep
Default Corroded strut Tower
Hi. Is there anyone here that lives within 100 miles of Chicago that can repair the corroded strut tower on my 18 year old daughters 1999 Caravan? She desperately needs transportation. We put it up for sale in order to purchase something else because we cannot afford to have this fixed through the dealership, and two out of two guys told me she could be killed driving this with the strut tower in this condition. My only recourse is to sell it to some unknowing person, however unlike Dodge/Chrysler Corporation, I have a conscious.
Old Jun 19, 2011 | 11:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Here is the kit numbers if you have your shop to perform the repairs.
NUMBER: 23-044-02
GROUP: Body
SUBJECT:
NS Strut Tower Corrosion
OVERVIEW:
This bulletin involves correcting a corrosion staining, surface corrosion, or corrosion
perforation condition at the top of the strut tower/s.
MODELS:
1996 - 2000 NS Town&Country/Voyager/Caravan
SYMPTOM/CONDITION:
Cosmetic corrosion or perforation at upper strut tower/s usually between the strut
and upper load path beam inner panel (inner fender).
DIAGNOSIS:
Inspect left and right strut towers for condition. If corrosion is present, perform
one of the following repair procedures.
NOTE: ANY UNDER HOOD LABELS REQUIRING REPLACEMENT DURING THESE
REPAIRS SHOULD BE OBTAINED PRIOR TO BEGINNING REPAIRS.
PARTS/MATERIALS REQUIRED:
Qty. Part No. Description
1 05080009AA Strut Cap (Left Side)
1 Kit 05086513AA NS Strut Cap Installation Kit
(Left Side).
1 05080008AA Strut Cap (Right Side)
1 Kit 05086512AA NS Strut Cap Installation Kit
(Right Side).
11/2 - 2 Cartridges
Per Side
05083855AA Mopar Structural Adhesive
EQUIPMENT REQUIRED:
W-7804R 90-degree drill motor (PSE)
W-861 High-speed air cutter (die grinder) (PSE)
23-044-02 -2-
05016570AA Adhesive dispenser (MOPAR)
W-AK175 ACH Power set rivet gun (PSE)
REPAIR DESCRIPTION:
Repair A - Cosmetic corrosion removal and the application of corrosion
resistant materials and/or primers and topcoats.
Repair B - Corrosion perforation removal and installation of 1 or 2 new cap/s and kit/s.
NOTE: REPAIR PROCEDURES ARE OUTLINED IN THE INSTRUCTION
SHEET INCLUDED IN THE PARTS KITS.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation
No:
Description Amount
23-85-86-90 Perform Repair Procedure A- Surface
Corrosion (Rusted) - One Side
1.7 Hrs.
23-85-86-91 Perform Repair Procedure A- Surface
Corrosion (Rusted) - Both Side
2.6 Hrs.
23-85-86-92 Perform Repair Procedure B- Corrosion
Perforation(Rust Perforation) - One Side
3.9 Hrs.
23-85-86-93 Perform Repair Procedure B- Corrosion
Perforation (Rust Perforation) - Both Side
6.8 Hrs.
FAILURE CODE:
87 Rusted
P1 Rust Perforation
Old Jun 20, 2011 | 12:34 PM
kathiep's Avatar
kathiep
I actually cannot afford to fix this correctly at a shop. I found a ditzy chick to buy it though, she didn't even look under the hood. Guess it comes down to her or my kid driving when the strut shoots out.
Old Jun 26, 2011 | 04:54 AM
peshewa's Avatar
peshewa
A good body shop should not charge more than 2-3 hundred for that repair. Some will do it for less. Ebay has the replacement steel strut tower cap that goes bad on them for about $20 each and it can be done in 1 day easily.
