Engine Fuse
Old Jun 23, 2011 | 05:42 PM
bobr1961's Avatar
bobr1961
Default Engine Fuse
I've got a 1999 Caravan and over the last couple of week I have blown the 20 amp engine fuse, the van has all of the power but will not turn over until the blown fuse is replaced. Both times it has been when I first started the car and began to move....any thoughts?
Old Jun 24, 2011 | 12:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have a 2.4L engine? If you do, replace the starter. The starter is drawing too much amps and causing the fuse to blow.
Old Jun 24, 2011 | 01:35 PM
bobr1961's Avatar
bobr1961
It is actually the 3.3L engine....still same issue?
