Please help! Weird caravan ignition!
Old Jun 28, 2011 | 01:38 PM
guitarguy5254's Avatar
guitarguy5254
I'm not sure, I do not believe the charging system is working because: and to clarify I misspoke a bit, I removed the negative jumper cable from the van while it was idling after I had it started and the van died.
Old Jun 28, 2011 | 01:49 PM
guitarguy5254
I do not believe so, and I may have misspoke before, the van will start when jumped and will die if the negative jumper cable is removed.
Old Jun 28, 2011 | 01:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
Either charge the battery or replace and then check the charging system with a DVOM or a shop. You should be charging between 13.5 to 14.2 volts.
