transmission fluid change
Old Jun 29, 2011 | 10:40 PM
my00durango's Avatar
my00durango
Default transmission fluid change
the fluid i removed was burned all most dark red on the edge of being brown today i drained the fluid my question is how do i replace the rest of the fluid i was told buy a few good transmission places that they do not recommend transmission flushes that it does worst then it does good do i just add the fluid and change it in 30k please i need advice.
Old Jun 29, 2011 | 11:20 PM
wtribeflyer's Avatar
wtribeflyer
Drop the pan, change the filter, replace the fluid in the pan. Wait a few weeks. Do it again!. This will slowly replace all fluid. Its better than a flush.
Old Jun 29, 2011 | 11:45 PM
gentz's Avatar
gentz
In my best opinion, drop the pan, change the filter and re-install...The only way to actually drain all the fluid or exchange it is with a Machine, dealer or private shop...as a diy'er just drop the pan change filter and use some good atf.
Old Jun 30, 2011 | 03:17 AM
Cougar41's Avatar
Cougar41
Do yourself a favor. Buy a pump and pump the fluid out the dipstick the second and third time.
Old Jun 30, 2011 | 08:48 AM
trophyslayer's Avatar
trophyslayer
I bought a new pan with a drain plug in it, so when I changed my fluid I installed the new pan, then I would drive for 100miles pull the plug and refill, I did that 3x so with the laws of diminishing returns(some of the drained fluid would be the new fluid I just put in) I ended up with around 85% new fluid in it,
