transmission compatabilitly
Old Jul 5, 2011 | 02:37 PM
sqishie's Avatar
sqishie
Question transmission compatabilitly
I have a 96 plymouth voyager se with a 3.3 engine. I need to know if the transmission is compatible with a 2000 dodge grand caravan with a 3.3
Old Jul 5, 2011 | 08:23 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the Caravan section,
FF
Old Jul 6, 2011 | 12:12 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
1996 was a funny year for the minivans. That was the only year that there was two (2) 41TE/A604 transmissions. You had one 41TE without a TRS and the other was with a TRS (transmission range sensor) I would need to know which transmission you have, to be able to tell you.
Old Jul 6, 2011 | 09:54 AM
wtribeflyer's Avatar
wtribeflyer
X2. If you have the trans with TRS its a pretty easy conversion. But first see if you have the TRS. I am running a 1996 GC 3.3 with a 2003 transmission. The range sensor is just above the fluid pan on the front left corner of the trans. Like...below the battery. It will have around 10 wires going to it.
