2002 grand caravan idles a bit low
Old Jul 13, 2011 | 07:40 AM
lfforte's Avatar
lfforte
Default 2002 grand caravan idles a bit low
I have a 2002 3.3L grand caravan. It used to idle smoothly at about 700rpm. Now thw idle has dropped to about 600 rpm and idles a bit rough. What could be the cause? Could it be the TPS? Thanks
Old Jul 14, 2011 | 02:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you try cleaning the throttle body and AIS motor first. Then replace the TPS, But only use a mopar sensor if you do replace it.
Old Jul 18, 2011 | 04:08 PM
lfforte's Avatar
lfforte
Originally Posted by master tech
Welcome to DF
Thanks! I cleaned the throttle body and it seemed to have helped.
How do I clean the AIS mototr? Is it easy to remove?
Old Jul 18, 2011 | 08:38 PM
master tech
If the Idle is fine, then leave the AIS motor along. It has only one 25 torq holding it to the throttle body.
