Which wire do I need to connect to for LEDs mounted in fog light openings?
Old Jul 18, 2011 | 04:45 PM
Black3SR's Avatar
Black3SR
Default Which wire do I need to connect to for LEDs mounted in fog light openings?
I want them to come on whenever ignition is on. So they will be independent of any other lights. At worst I guess I could connect to the parking/signal lights. I see there are three wires there. One is a ground and one of the others is parking with the third being signal?
Here is a pic.
Thanks for any suggestions and or wiring diagram/colours would be helpful
Old Jul 18, 2011 | 06:23 PM
Tizzy1's Avatar
Tizzy1
what year is it?
Old Jul 19, 2011 | 05:10 AM
Black3SR's Avatar
Black3SR
On further searching I am thinking of adding a
Cooper Bussmann/ATM fuse tap to one of the 20 amp circuits in the fuse box once I find out which one to use.
Old Jul 19, 2011 | 04:38 PM
Black3SR's Avatar
Black3SR
Tizzy 1 - How about the 20 AMP at M6? I see a ground wire to frame down below and in front of the battery for the ground wire.
Old Jul 20, 2011 | 09:57 AM
Tizzy1's Avatar
Tizzy1
Looks like a good one to me. It is an ignition feed.
Old Jul 20, 2011 | 12:12 PM
Black3SR's Avatar
Black3SR
All done
I ran wires behind the black whatever. I drilled pairs of two small holes and used black ties
Ground is small black wire coing in from the right to ground nut
Because of seal on fuse box I had to drill a samll hole for wire then added some GOOP to seal it
I am happy. Now if I could correct my name here. It should be Black3sr eh like Dale.
