2005 Wipers running slow in fast mode
Old Jul 19, 2011 | 12:46 PM
bdp278's Avatar
bdp278
Default 2005 Wipers running slow in fast mode
When I turn my wipers to fast speed, they just run in slow speed. Sometimes they will just kick in fast speed, run that way for a short while, then fall back to slow speed. I know the turn signal switch (which is also wiper control) on the steering column is probably suspect, but are there any other relays and/or modules, incl the motor, that I should check or replace, and if so, where would they be located?
Old Jul 19, 2011 | 03:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Do you know if the recall F10 was done? Here is part of the recall. The speed control is done from the BCM. You may need to check for any stored codes in the BCM. If you don't know if the recall was done, just send me a pm with the last 9 of the vin and mileage too.
June 2006
Dealer Service Instructions for:
Safety Recall F10 - Windshield Wiper Motor
2005-2006 (HB) Dodge Durango
NOTE: This recall applies only to the above vehicles built between March 29, 2005 and June 12, 2005 (MDH 032905 through 061223) OR between September 27, 2005 and November 23, 2005(MDH 092701 through 112323).
2005-2006 (RS) Chrysler Town & Country and Dodge Caravan/Grand Caravan
NOTE: This recall applies only to the above vehicles built between March 28, 2005 and July 1, 2005 (MDH 032823 through 070123) OR between September 27, 2005and December 13, 2005(MDH 092701 through 121323).
IMPORTANT: Vehicles that have already had the proper wiper module installed, according to warranty records, have been excluded from this recall. In addition, 2001 through 2006 model year RS vehicles (built outside of the above MDH ranges) that have had a suspect replacement windshield wiper motor (P/N 05114534AA) installed between March 21, 2005 and January 13, 2006, according to warranty records, have been added to this recall. Dealers are also requested to review their records and contact owners who have purchased a wiper motor or who have had a wiper motor installed outside of the warranty provision. There were no suspect HB replacement wiper motors shipped to Mopar.
