2002 GC knocking sound
Hello and thanks for taking the time to help me. My GC has a knocking sound when it is put in reverse or drive and held in place. I hear the sound until about 2-3mph then it is gone. No knocking when engine is idoling, I have replaced the harmonic balancer, water pump and tensioner pulleys to no avail. Is it possible that it could be a timming chain slap? Any help would be appreciated.
Welcome to DF
It could be a cracked flex plate or loose torque converter bolts. Remove the inspection cover and check the 4 18mm bolts threaded in the torque converter. If they are tight, then I would start thinking about a flex plate. Yes the transmission need to be removed to replace the flex plate.
look ed bolts and they were tight. I ended up taking the serpintine belt of and noise went away. Through further investigation I found that it was the ac compressor. Thanks for the Help though.
first- I'm new to this forum, so hi there everybody.
second- I have an issue with my 2007 dodge GC. It has a knock. A hard knock. It seems to be that the noise became louder as the van got wormer. befor the knock there was a tick. The tick went away for about two weeks. the noise came back as a knock.
Please help as i have been chasing my tail on this.
Thank you in advance,
Neudaddy
Neudaddy
so im looking at a timing belt replacement. does anyone know about how much they cost for 2007 GC.
Trending Topics
You must have the 2.4 ltr engine. A timing belt will cost around $30. To have it installed around $300. The 3.3 and 3.8 ltrs use a timing chain.
Question: is the timing chain kit for the 2007 3.8L the same as the 2003 3.8L I checked orielly's and Napa, both don't have one. i'm going to call an engine shop here in town and hopefully it works. I was told it might be a dealer item
Any further help would be absolutely great.
