A/C causes Van to sputter
Old Jul 27, 2011 | 01:52 PM
O2Caravan's Avatar
O2Caravan
Default A/C causes Van to sputter
Hi! A few months ago I asked a question here, but I don't think I explained the situation correctly.
I have a 2002 dodge caravan that's been having an issue: It gives a sputter ONLY when the AC is on at 40mph, 60mph, 80mph, and when coming to a stop (only happens when AC is on and car's been taxed for awhile). No check engine light, although we were having it come on throwing PC0351 and since replaced the ignition coil, and it hasn't come back on since. Mechanic won't touch it because check engine light isn't coming on, which drives me crazy because obviously there's a problem (thinking it's time for a new mechanic!).
Changed ignition coil; changed plugs; the wires looked good. Husband feels like it's an electrical transmission issue, but wouldn't it throw a code? I don't understand why this is clearly an issue, and yet no code.
Any ideas?
THANKS!
Old Jul 29, 2011 | 12:21 AM
master tech's Avatar
master tech
Site Moderator & Tech
Here is a TSB, This or may not be the problem you are having.
NUMBER: 18-008-02
DATE: Feb. 11, 2002
SUBJECT:
Engine Sag/Hesitation And/Or Closed Throttle Start Stall
OVERVIEW:
This bulletin involves replacing the Throttle Position Sensor (TPS).
MODELS:
2001 - **2002** (RS) Caravan/Voyager/Town & Country
2001 - **2002** (RG) Chrysler Voyager (International Market)
NOTE: **THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 3.3L OR 3.8L
ENGINE AND BUILT BEFORE OCTOBER 01, 2001 (MDH 1001XX).**
SYMPTOM/CONDITION:
Engine hesitation/sag, closed throttle start/stall, and/or Diagnostic Trouble
Code (DTC) P0123 – “Throttle Position Sensor Voltage High”. May be more
prevalent in cold temperatures below 0 C. (32 F.).
DIAGNOSIS:
If no DTC’s are present or DTC P0123 is present, perform the Repair Procedure.
If other DTC’s are present further diagnosis is required.
PARTS REQUIRED:
Qty. Part No. Description
1 04686360AB Sensor, Throttle Position
REPAIR PROCEDURE:
1. Disconnect the negative battery cable.
2. Remove the electrical connector from the Inlet Air Temperature Sensor.
3. Remove the air cleaner box lid. Remove hose from throttle body.
4. Disconnect the electrical connector at the TPS.
5. Disconnect the electrical connector at the Idle Air Control (IAC).
6. Remove the three (3) TPS mounting bolts and TPS.
7. Reverse the previous steps to install new TPS, p/n 04686360.
