99 Caravan no Reverse
Old Jul 30, 2011 | 03:44 PM
z11211z's Avatar
z11211z
Default 99 Caravan no Reverse
Has the 4 cylinder. Forward gears all good. Am I looking at a new trans or able to fix this one? Thanks
Old Jul 30, 2011 | 05:02 PM
vpnavy's Avatar
vpnavy
Until someone pipes in - I searched the net and found this...
"...QUESTION: 1999 Dodge Caravan Does not go in reverse - ANSWER: The shift soleniod is the most logical answer or the shifter cable has to be adjsuted. I do not think the gears are an issiue. Is you fliud clean? Does the fuild smell burnt or dark in color. Is there metal shaving in the fluid? If any of the above condition exist then you should take the vehicle in for service..."
Old Jul 30, 2011 | 05:16 PM
gentz's Avatar
gentz
usually this is a good indication of a bad transmission.. I suggest either rebuild it or install a rebuilt..will be more cost effective..
Old Jul 30, 2011 | 06:42 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the van have a 3 speed transmission or a 4 speed? If the transmission is a 3 speed, remove the pan and inspect the strut for the reverse band. If the strut is missing. This will cause a no reverse, because the level can not apply the strut to the band. So it may not need an overhaul.
Old Jul 31, 2011 | 01:52 PM
z11211z's Avatar
z11211z
Thanks for the replies
