2000 caravan no gauges or signal to dlc
Old Aug 1, 2011 | 12:52 AM
kr125's Avatar
kr125
Default 2000 caravan no gauges or signal to dlc
hi there im workking on a 2000 caravan all the gauges do not work at all and there is no communicaution with dlc and the check engine light is on any ideas?
Old Aug 1, 2011 | 11:45 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You need to start why you have no communtication at the DLC first. What type of scanner are you using?
Old Aug 1, 2011 | 11:03 PM
kr125's Avatar
kr125
im using a2010 modus snap on scanner i have power to all the dlc pins that should have power except the bus ccd + has very little and the bus ccd- has power too dont know if that should have power and those wires go to every computor and the gauges and all the grounds are good on the dlc
