99 Caravan, Problem With Radiator Fan
Old 08-02-2011, 12:10 AM
Conquista's Avatar
Conquista
Conquista is offline
Default 99 Caravan, Problem With Radiator Fan
There are actually 2 radiator fans in this Caravan.
Today,out of nowhere, the car started to overheat. The temp is usually smack in the middle of the gauge or lower, but today is started quickly climbing to the top. I let it rest awhile, then turned it back on and realized neither radiator fan was working.
I checked the fuse and it looked old and beaten, so I changed it. As soon as I did, one of the fans started working and the car stopped overheating. However, the other one won't budge. The "service engine soon" light came on and is staying on.
What can I do to get the other fan working?
Old 08-02-2011, 01:14 AM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Try spinning the fans by hand. If they bind change them before you fry that $75 cooling fan relay.
Old 08-02-2011, 03:55 PM
ez1913's Avatar
ez1913
ez1913 is offline
Check your local junkyard for fans.
EZ1
Quick Reply: 99 Caravan, Problem With Radiator Fan
