transmission fluid/filter change
Hey everyone
My mom calls me up whenever she has a problem with her van and i do what i can to fix it. Yesterday she called me saying it was shifting hard, shes owned the van since 03 and has not done anything to the transmission since than so i figured fluid and filter change is a good place to start. The fluid that was in there was grey and everything is going fine except for some confusion im having over how much to put in. I took out just under 5 liters of grey fluid, from what i can find online and in the repair manual is says 9.1 quarts which is about 8.5 liters, i dont see how the van could of lost the much fluid? am i only suppose to put in 5 liters? is the book wrong? any help would be great thx
This is the vehicle info
2000 dodge caravan base
3.0L engine
4 speed auto tranny 41TE
3.0L engine
okay thanks, haynes manual does not specify the difference between total refill and filter change like it does on other ones i have. The owners manual is missing do i check the fluid while the van is running or no?
Just read this - don't know if it is true or not - I'm sure a Technician will jump in on this if it is false: You should always disconnect the battery. Yes, it will reset the computer but it will also make smoother shifts with the new fluid.
