Smoking engine
Old Aug 10, 2011 | 09:17 PM
dodgeforce39's Avatar
dodgeforce39
Default Smoking engine
Two issues:
1. Oil leaking from from crankshaft seal area, Other than doing a complete front end disassembly, anychance these oil conditioners might help?
2.Notice engine smoking a little blue smoke during driving. Heard something about PVC could cause. What do I need to check there if that's the case.
I assume it's the seal and not the pan gasket. it's coming from the curved area of the front pan. Can't really see what's going on exactly.
Old Aug 10, 2011 | 11:18 PM
master tech's Avatar
master tech
Site Moderator & Tech
What size is the motor? I hope its not a 2.4L.................
Old Aug 11, 2011 | 09:20 AM
dodgeforce39
3.0 140,000 miles
Old Aug 11, 2011 | 11:36 PM
master tech
The bad news the blue smoke when driving, maybe rings and valve seals. That is common on mitsubishi motors with high mileage. The good news, they can be repaired. You may have more than just the crank seal leaking. I would add engine dye and use a black light to find the leak. The reason I ask if the motor was a 2.4L, If oil is leaking from the crank seal. You may as well order a new motor. What happens is the crankshaft has a shim to hold the crank in place in the block. Sometimes the shim falls off into the pan and the crank starts walking and push the seal out and cause a leak.
