95 dodge grand caravan radio no power
Old Aug 17, 2011 | 08:39 AM
redlas's Avatar
redlas
Default 95 dodge grand caravan radio no power
A few days ago my radio/cd player just stopped working there seems to be no power going to it, and I cant find my owner manual to look up the wiring , the fuse seem to be ok. But there is a plug9dont know what it is for) by the fuse panel that seems to be unplugged but cant see where it plugs into.
Can anyone help me..'''' thanks
Old Aug 17, 2011 | 09:24 AM
Tizzy1's Avatar
Tizzy1
have you checked for power at the radio itself? The fuses for the radio are fuse 6 in the fuse block which is ignition power and fuse 1 in the PDC which is the battery feed.
Old Aug 17, 2011 | 09:30 AM
redlas's Avatar
redlas
thanks I will try,, if I can find what you are talking about lol
Old Aug 17, 2011 | 09:35 AM
Tizzy1's Avatar
Tizzy1
There is a fuse box inside the vehicle on the drivers side, that is where fuse 6 will be found, there is a fuse box under the hood (PDC) and that is where fuse 1 can be found.
Old Aug 18, 2011 | 07:53 AM
redlas's Avatar
redlas
I checked both places and all fuses were fine, any other suggestions.
Old Aug 18, 2011 | 09:13 AM
Tizzy1's Avatar
Tizzy1
Pull the radio and check it there, if you have power and ground, the radio is bad. Power is the pink and red wires, ground is the large strap.
Old Aug 18, 2011 | 12:54 PM
redlas's Avatar
redlas
ok thanks will try that
