1997 dodge caravan wont start after new trany installed
Old Aug 18, 2011 | 11:00 AM
LFTB's Avatar
LFTB
Talking 1997 dodge caravan wont start after new trany installed
I have a 1997 Dodge caravan, we replaced the Transmission,and now it will turn over but won't start...Its a 3.8 6 cyl...
When the transmission went out,I was driving down the road,I heard a loud metal POP,and all the gears were gone,and I drifted to safety...Is there a safety feature on the caravan that shuts down anything,that could be re-set?
I am desperate,and have heard to check the crank sensor...winter is on the horizon,and I need my car back...please help!!!
Old Aug 18, 2011 | 11:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If the van ran before the transmission was replaced, then I would start at the crank sensor and wires. Did you add the little cert at the bottom of the crank sensor? Thats to adjust the air gap.
Old Aug 20, 2011 | 12:46 PM
LFTB's Avatar
LFTB
Default Caravan Trany issue
Ok,Thank you so much...How do you adjust the sensor(sp?) crank?We have it off and am not sure if it gets replaced or you adjust it,Thank you again,LFTB
Old Aug 20, 2011 | 02:21 PM
master tech
You should have a round paper that sticks to the bottom of the sensor. All you do is put the sensor in the hole and tighten the 10mm bolt.
