No heat on pass 00 Gr. Voyager
BLEND-AIR DOOR ACTUATOR
REMOVAL
The air conditioning system can be equipped with either a standard, single blend-air door actuator, or it can be equipped with dual actuators. The dual system has separate blend-air controls. This allows for separate control of the driver's side air, and the passenger side air
1 = drivers side blend door actuator
2 = Mode door actuator
3 = Passenger side blend door actuator
REMOVAL
- Remove the lower left side steering column cover. Refer to Group 8E, Instrument Panel and Systems.
- Remove ABS control module
- Remove blend-air actuator connector.
- For installation, reverse the above procedures.
- Perform the HVAC Control Calibration Diagnostic and Cooldown test. Repeating the test is necessary to clear the fault codes.
