ABS light on all the time
On my 2003 Dodge Caravan the ABS light stays on all the time. I searched to see if anyone had posted the same problem but, they all had the brake light on also. My brakes seem to work fine. Brakes were changed last year. A couple of times the light went off and when the brakes were applied the pedal jumped pretty bad. I had a scanner put on the van a couple of days ago but no brake problems came up on the scanner. If anyone can lead me on how to check things out it would be great.
jahenbo
jahenbo
abs faults can not be read by regular code readers, will need either have dealer pull them or most shops will have a good scanner that can pull them, some will pull codes for free, will have to call around and ask if they pull codes for free
