2010 Caravan: Break Lights, Rear Turn Signal Issue
Old Sep 1, 2011 | 06:48 PM
RRFish's Avatar
RRFish
Default 2010 Caravan: Break Lights, Rear Turn Signal Issue
Hey all,
New to the forums. I have recently purchased a used 2010 Dodge Caravan. They brake lights and rear turn signal lights are not working. I understand this may be a fuse issue that I could fix cheaply and quickly.
I don't know the first thing about working on cars, so could you tell me in layman's terms which fuse(s) I should pull and replace from the fuse box. (Also can I hand pull these fuses or do I need a tool to pull them?)
Thank you in advance.
(Also I didn't get a manual for the vehicle.)
Old Sep 2, 2011 | 11:27 AM
Tizzy1's Avatar
Tizzy1
the fuse is in the fuse box under the hood, it is the M01 fuse and is a 15 amp fuse. It should be listed on the cover of the fuse block.
The owners manuals are online at dodge.com, they don't come with a printed version anymore but they can be purchased.
Old Sep 3, 2011 | 01:09 AM
steak59's Avatar
steak59
does the 3rd brake light works?
You probably just need 2 lightbulbs.
Old Sep 3, 2011 | 10:27 AM
RRFish's Avatar
RRFish
Yes. The third break light works. So it might be a bulb issue? That sounds like it would be an easier fix.
Thank you both for the reply.
Old Sep 7, 2011 | 08:32 AM
RRFish's Avatar
RRFish
Thanks again to everyone who contributed. Steak59, you were right. I replaced the lights. It looks like the wrong lights were in there (3457 instead of the 3157's it should have had). I'm not sure if that makes a difference, but now my turn signals and my break lights are working.
