Power sliding rear door lock
Old Nov 23, 2012 | 12:14 PM
mohrmanr's Avatar
mohrmanr
Default You can work around the window
Buy 2 #6 bolts 4in long or so. Put the window in the up position and then screw the bolts in the threaded holes under the window to keep it in the up position. I was able to pull the actuator and replace it this way without removing the glass.
Old May 9, 2017 | 03:51 PM
David Sawyer's Avatar
David Sawyer
Thank you for your great diagrams of the "Guts" inside the sliding doors !!
But I can not even get the dammed Interior door panel Off !!
on my 2004 - I can not pull up the door lock **** - it is stuck in the down position and as STUPID AS IT SEEMS ! - It is a catch 22 situation ! -You need to open the sliding door first !! - in order that you can remove the door panel to get access to the Locking mechanisms - - - But the door is locked & will not Open - so I can not get the interior door panel off and that's pretty STUPID - !!! - Can anyone help with tis problem ??
